jb_41530
Oct 29, 2014Running code 9.4.6 is there a command equivalent to ver 11.4's SSL Protocol Version 3
trying to see how many clients are using sslv3 on a old code production ltm.
- shaggy
I don't have a place to test, but I would start with the following:
b profile clientssl [(profile clientssl key list) | all] show b profile clientssl [(profile clientssl key list) | all] stats show - jb_41530
commad is - show /ltm profile in ver 11.4 need 9.4.6 equivalent - jb_41530
Thanks Shaggy, I tried the options but all I can generate is the connections, encrypt, decrypt stats. If I use b ssl I do get global stats on the sslv3 protocol version use but this does not display which ssl profiles/vs is accepting this version.
- jb_41530
found the correct string to get the results I wanted. b profile clientssl show all Thank you shaggy! JB
