Fahad_A__Bin_Ma's avatar
Fahad_A__Bin_Ma
Nov 17, 2007
RPC over https for exchange 2003
i am deploying LTM in front my front end OWA server. before getting LTM in the picture i use RPC over https proxy for my outlook client. Currently i offload the SSL from front end OWA to LTM but the problem is my RPC over https for outlook is not working with me????
  • hoolio's avatar
    hoolio
    Do you have more information on what's not working? Typically, when you offload SSL for OWA, you have to insert a custom HTTP header, FRONT-END-HTTPS with a value of 'ON' to tell OWA to use https:// in redirects and links in the content it sends back to clients. If this is the issue you're seeing, try searching devcentral for this header name for more info.
    If this isn't the cause of the issue you're seeing, can you elaborate?
    Thanks,
    Aaron
  • Hi,
    i got the solution for this. there is some thing on IIS need to be change to let it work.
    and this IIS change ( http://technet.microsoft.com/en-us/library/bb124604.aspx) solve the problem
    Thanks,
    Fahad
