Routing LTM data traffic among 2 interfaces
Hi Experts
If one interface (1.1) of LTM is passing data traffic , is it possible that data traffic from another interface (1.2) can send the traffic to 1.1 ? If yes please let me know how the routing will happen among 2 interfaces ? Also is it possible that the VLAN2 of one interface (1.1) can send the traffic to VLAN3 of same interface ?
If it is possible do we need to change the VIP Type to 'Forwarding" or need to keep it "Standard" ?
Ankur
- James_Thomson_0Historic F5 Account
Ankur, In your scenario, is interface 1.1 tied to vlan1 and interface 1.2 tied to vlan2 ?
By default, the BIG-IP won't route between subnets unless there is a virtual server directing it to do so. If you had a scenario like this: vlan1 (1.1) - self 10.10.10.0/24 vlan2 (1.2) - self 20.20.20.0/24 and you wanted traffic to go from vlan1 to vlan2, then you would create a forwarding virtual server where the destination is the subnet tied to vlan2.
Virtual Server: Destination 20.20.20.0/24 type forwarding.
That would allow traffic destined for 20.20.20.0/24 to follow the routing table.
If you wanted to limit it to only traffic FROM vlan1 can go to vlan2, then in that virtual server, enable it only on vlan1.
More information on forwarding virtuals: https://support.f5.com/kb/en-us/solutions/public/7000/500/sol7595.html
