Round Robin Load Balancing is not Balanced
Hello DC,
I have a problem with our new application which using round robin method for load balance, but it's seem not balanced with my two pool members by I checked on the statistics I see the traffics go to only one pool member. I didn't use a persistence or OneConnect profile on my VS.
Anyone have any idea or advice on this?
Phaneath
- jaikumar_f5
Noctilucent
Can you run the below commands and share us the output. Is there any priority group set on the members ?
tmsh list ltm pooltmsh show ltm pool members | grep -E "Pool Member|Total Connections" - KevinA_246454
HI
Please have a look add your tmm instances running on your f5 appliance run this command "tmsh show sys tmm-info | grep Sys::TMM"
Each TMM instance runs a its own load balancing process, please see this link for more info on cmp.
https://devcentral.f5.com/questions/round-robin-in-cmp-based-ltm
