Squeak's avatar
Squeak
Icon for Cirrus rankCirrus
6 years ago
Rewrite issue with Portal Access
Hello,
I´ve a rewrite issue with a internal webpage that I´m publishing with Portal Access. The APM module adds "F5CH=I" to the image path and "F5CH=C" to the css path.
 styles.css?F5CH=C
 /images/icon-search.png?F5CH=I
I found out that this is a known bug and I created an IRule to fix it.
  set wtType [ACCESS::session data get session.policy.result.webtop.type]
  if {[ info exists wtType ] && $wtType == "full" } {
    if { !([HTTP::uri] starts_with "/f5-w") && ([HTTP::uri] contains "styles") && ([HTTP::uri] contains "/images")  } {
       log local0. "===>  Before  ====> [HTTP::uri] "
       HTTP::uri "/f5-w-MASKED_HEX$$[HTTP::uri]"
       log local0. " Corrected ====> [HTTP::uri] "
  unset wtType
But without any success.
Any suggestions what I´m missing?
  • Hi Squeak,
    I think, you should use "||" operator instead of "&&" operator
    	if { [info exists wtType] && $wtType == "full" } {
    		if { (not ([HTTP::uri] starts_with "/f5-w")) && (([HTTP::uri] contains "styles") || ([HTTP::uri] contains "/images")) } {
    			log local0. "====> Before ====> [HTTP::uri] "
    			log local0. "Corrected ====> [HTTP::uri]"
    	unset wtType
