steve_111974
Jul 24, 2008rewrite a character with HTTP POST data
Our application is having a problem recognizing the "&" within a POST sent by the client.
How do I write an irule which parses the POST data that contains the "&" sign and rewrite it to something else like "and", then pass it to the application server. I might need help on rewriting the "and" back to "&" for the response back to the client.
Here's a sample of the data being sent by a client:
POST /app/DentegraPortal/TransEDI HTTP/1.1
Content-Length: 514
Content-Type: text/plain; charset=UTF-8
Host: 192.168.130.129:8080
Connection: Keep-Alive
User-Agent: Jakarta-HttpComponents/1.1
ISA*00* *00* *ZZ*DDPA *ZZ*NY *080724*1127*U*00401*000000001*0*P*:~GS*HS*DDPA*NY*20080724*1127*1*X*004010X092~ST*270*0001~BHT*0022*13*DDPA-deprod2-1216916839069-0*20080724*1127~HL*1**20*1~NM1*PR*2*DELTA DENTAL NY*****PI*NY~HL*2*1*21*1~NM1*1P*2*MONTERUBIO & HERBOSA ORAL M*****FI*431554961~HL*3*2*22*0~NM1*IL*1*CONWAY*NATSUKO****MI*489846656~DMG*D8*19560225~EQ*30~SE*11*0001~GE*1*1~IEA*1*000000001~
Please help!
- Colin_Walker_12Historic F5 AccountAll you would need is an iRule that does inspection of the client data once a post is sent, and content replacement. You could use a string mapping or a regular expression, based on your needs. Have you searched the forums yet? There should be a few good examples either here or in the CodeShare.
Colin - hoolio
A stream profile and rule to enable it should work nicely to rewrite the post data in requests. You'll want to try to be very specific on when you rewrite the & as this is typically used as a delimiter for post data parameters. You might want to use something like this:when HTTP_REQUEST { Disable the stream filter by default STREAM::disable Check if the request is a POST, with a content type of text, from the Jakarta user agent if {[HTTP::method eq "POST" && [HTTP::header value Content-Type] contains "text" \ && [HTTP::header value "User-Agent"] contains "Jakarta-HttpComponents"}{ Match the literal string "&" and replace it with and STREAM::expression {@&@and@} Enable the stream filter for this request only STREAM::enable } } when STREAM_MATCHED { This event is only included for debugging. You should remove the event after testing is complete. log local0. "[IP::client_addr]:[TCP::local_port]: matched: [STREAM::match]" }
You could use a similar approach for rewriting the and back to & if it does appear in responses. Again, you'd want to try to be very specific about when you're rewriting the content as 'and' is a very common string.
Aaron - hoolio
Actually, I would guess your app expects the & to be URL encoded if it shouldn't be interpreted as an &. I think you could replace the stream expression line in the example above, with:
STREAM::expression {@&@%26@}
I don't think you'd need to do any rewriting on responses if the application is standards compliant.
Aaron - steve_111974
Colin, I've checked the codeshare section and it suggested to use the http:collect and http:payload parameters. I tried building one from scratch but kept getting errors on the irule.
Aaron, all the requests are POST so I commented the" if" statement out. So for the expression, I should use
instead of
I'm not sure what you mean by "URL encoded".
Also, when I look at the raw data, i see a "&" but I when export it and view in html, it shows just "&". Which one should I filter for?
thanks so much for the quick response!
Steve - hoolio
Here is some info on URL (or percent) encoding:
http://en.wikipedia.org/wiki/Percent-encoding
Percent-encoding reserved characters
When a character from the reserved set (a "reserved character") has special meaning (a "reserved purpose") in a certain context, and a URI scheme says that it is necessary to use that character for some other purpose, then the character must be percent-encoded. Percent-encoding a reserved character involves converting the character to its corresponding value in ASCII and then representing that value as a pair of hexadecimal digits. The digits, preceded by a percent sign ("%"), are then used in the URI in place of the reserved character.
The reserved character "/", for example, if used in the "path" component of a URI, has the special meaning of being a delimiter between path segments. If, according to a given URI scheme, "/" needs to be in a path segment, then the three characters "%2F" or "%2f" must be used in the segment instead of a raw "/".
This blog entry (Click here) suggests you may need to XML encode the element value and then URL encode it. So the XML encoded equivalent for & is & amp ; (without the spaces). & amp ; (without the spaces) URL encoded would be %26amp;.
If you're able to test this, try the following rule which replaces & with %26amp;when HTTP_REQUEST { Disable the stream filter by default STREAM::disable Check if the request is a POST, with a content type of text, from the Jakarta user agent if {[HTTP::header value Content-Type] contains "text" \ && [HTTP::header value "User-Agent"] contains "Jakarta-HttpComponents"}{ Match the literal string "&" and replace it with %26amp; STREAM::expression {@&@%26amp;@} Enable the stream filter for this request only STREAM::enable } } when STREAM_MATCHED { This event is only included for debugging. You should remove the event after testing is complete. log local0. "[IP::client_addr]:[TCP::local_port]: matched: [STREAM::match]" }
If that doesn't work, try replacing the STREAM::expression line with this:
Aaron
