Retrieving active NAT translations using iControl
We are planning to license the CGNAT module. One of the questions was whether iControl support retrieving a representation (preferably JSON or XML) of the active NAT translations.
So far i have come across the following interfaces.
https://devcentral.f5.com/wiki/iControl.LocalLB__LSNLogProfile.ashx https://devcentral.f5.com/wiki/iControl.LocalLB__LSNPool.ashx https://devcentral.f5.com/wiki/iControl.LocalLB__ALGLogProfile.ashx
Does anyone have any experience with the CGNAT module? Could really use some inputs.
Thanks.
- aj1
- StephanManthey
Nacreous
Hi aj,
you are probably aware of how to dump the detailled connection table (including all translation information) via tmsh:tmsh show sys conn all-propertiesBut I´m not aware of a equivalent via API.
As far as I can say the common approach is to log the connection details in real-time to a remote log server by using the HSL (high speed logging) capabilities. Thanks, Stephan
