Rerouting iRule not rerouting correctly
We've got an iRule that we've used for years which does redirection and rerouting.
Last week, I tried to change some of that routing, and it's mysteriously failing. When we look at cookies, the pool isn't the correct pool for the reroute. I'm puzzled why that would happen.
Hello John_Adams
Unfortunatelly you are not providing much info
Why cookies? Do you have cookie based persistence?Are you getting any tcl errors?
Can you share your rule?
Do you have backup before applying the recent changes?
- Melissa_C
Moderator
Hello John_Adams,
I noticed that Injeyan_Kostas had asked some follow up questions to assist. If this is something you have found the answer to please update your post and mark as solved, however, if not please respond try and respond to Injeyan so our community can try to further assist you.
Thank you for being a part of our community!
-Melissa
