goldenvxr_30118
8 years agoReplacing the battery on a Viprion 4400 Chassis
Hi Everyone,
I will be replacing the battery on a Viprion 4400 Chassis. The chassis is running just fine at the moment, but we are getting a critical alert to replace battery as soon as possible.
I read the manual, and the battery seems hot swappable. I know it sounds easy but is there any issue that may arise that I should think about before moving forward?
Any insight is helpful. Thank you in advance!!!
