Approxee's avatar
Approxee
Dec 28, 2013
Removing VLAN - and routing to Node
I am working with a customer that want to put all of their networks that are currently directly connected to the F5, behind another L3 interface. So we are now affectedly rouring to the node, rather than being directly connected to it.
When I try and delete the VLAN it produces the following message.
01070265:3: The VLAN (/Common/VLAN_xx) cannot be deleted because it is in use by a self IP (xx.xx.xx.xx).
I have added a default route, so the node is still reachable, so how do I remove the VLANs from the config
Graham
