Pete_Cranny_793
Dec 17, 2009Remote Desktop Connection Broker R2
Hi, I am trying to use Remote Desktop Connection Broker with BIG-IP v9. When I try and add the RemoteApp Source Name and add in the BIG-IP VirtualServer address I get an error "Unable to connect to FARMNAME. Do you still want to add FARMNAME as a RemoteApp source?"
The Connection Broker and Session Host servers are in the same subnet and the Session Host server works fine via the VirtualServer ip address. I can add the RemoteApp Source if add in the actual name of the server in the farm, but not the farmname.
The deployment guide for Terminal Server 2008 does not include R2 connection broker as it it pre R2. Can anyone help with configuring the connection broker as this is the only thing that doesn't work for me via BIG-IP.
The session broker server logs the following when trying to add the session host virtualserver address:
Event ID: 10009
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: xxxxxBROKER02.xxxxxxx.com
Description:
DCOM was unable to communicate with the computer xxxxxfarm01.xxxxxxxx.com using any of the configured protocols.
- Patrick_M__Stoe
Has anyone found a way to get this to work properly using route domains yet?
