Registration Key and Licenses are replaced and F5 is not working
I have copied the Backup .UCS file from 3400 F5 and restore this Backup file on 8900 . with this it has overwrite every thing my intentions were for Configuration. now 8900 GUI is displaying me the activation screen for License.
and i don't have support from F5 as machines are end of life. kindly tell me how to restore previous 8900 .UCS file so that the Reg Key and License for 8900 restored.
- nitass
Employee
you can do it in command line, can't you?
sol13132: Backing up and restoring BIG-IP configuration files (11.x)
http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13132.htmlby the way, license file and registration key (inside license file) are included in ucs. you can use tool such as 7zip to extract the ucs file.
- mubashir_133429
thanks for quick reply 8900 is with version 10.X and 3400 was 9.4.5 . and i have access to command line. u are saying that i can extract 8900 Reg key and License through 8900 backup .ucs file
- nitass_89166
Noctilucent
- mubashir_133429
- nitass
Employee
yes, both are in ucs file (license file is /config/bigip.license. registration key is inside the license file).
i use 7zip to extract ucs file.
7zip
http://www.7-zip.org/- mubashir_133429
how can i upload my old .ucs file from console as load sys ucs is not working
- nitass_89166
Noctilucent
7zip
