Eduardo_Saito_1's avatar
Eduardo_Saito_1
Dec 11, 2007
Regex taking 1% CPU - How to minimize CPU Load?
Hello Eveybody.
I'have an iRule that is working ok, but there is a regex thjat is taking 1% CPU on a 6400 BIG-IP.
How Can I minimize CPU load?
Here is the code:
The objective of this regex is to list all images (URI) of "http://image.domain.com" in the HTML code.
set image_match [regexp -all -inline -indices {http://image.domain.com/[a-zA-Z0-9/._-]+} [HTTP::payload]]
Thanks!
Eduardo Saito
  • hoolio's avatar
    hoolio
    Hi Eduardo,
    A regex will eat up CPU no matter how streamlined you get it. You can probably save a bit of CPU time by escaping the periods with a backslash:
    http://image\.domain\.com/[a-zA-Z0-9/._-]+
    Depending on what you want to do with the image references, you might be able to replace the regexp with a stream profile. What are you actually doing with the indices once you get them?
    Aaron
