Bala_02_152654
Jun 09, 2014Regarding FIPS 140-2 level 1 and level 2
Hello
Can any one suggest me a any tool available to verify the compliancy for FIPS 140-2 level 1 and level 2 after the HSM module been installed and the process to check the same.
Thanks Bala
- Eduardo_N__1674
You can check the license in the management interface, or potentially list the crypto modules. tmsh list sys crypto fips
This is NOT a tool to check for FIPS 140-2 compliance. For that you need to check the license number your hardware manufacturer provides against those on the NIST site.
