Anuj_Chaudhary_
Aug 08, 2016Reg health Monitor
Hi folks,
when we are applying https health monitor its marking the pool member down,but when we are applying TCP_443 its not marking.
What might be the issue ? why its happening ?
Anuj
- Vijay_E
Cirrus
TCP_443 is just performing a 3-way handshake on port 443. HTTPS performs 3-way handshake followed by SSL handshake. If TCP_443 works, it is fair to conclude that route to the pool member exists and the pool member has port 443 listening. If HTTPS is failing, I would check to make sure if there are any issues with the cert utilized.
