muzammil_88686
Jun 05, 2013Redirection iRule is going in loop
Dear Team,
We have the below two iRules.
if {([HTTP::header exists "X-Forwarded-For"]) and ([string tolower [HTTP::uri]] equals "/maxi/homepage.do")} {
switch -glob [HTTP::header values "X-Forwarded-For"] {
"9.23*" {
HTTP::redirect "http://www.test.com/MaXi/homePage.do?src=US"
return
"9.3*" {
HTTP::redirect "http://www.test.com/UK"
return
"9.102.*" {
return
elseif {[string tolower [HTTP::uri]] starts_with "/maxi"} {
pool Pool2
when HTTP_REQUEST priority 10 {
switch -glob [HTTP::uri] {
"/MaXi*" { pool Pool2}
default { pool Pool1 }
Redirection for 9.23* and 9.102.* are working fine without any issues.
Even for the 9.3* redirection is working fine and the user is getting the page "http://www.test.com/UK" successfully. But there is tab (URL "http://www.test.com/MaXi/homePage.do") on the page when he clicks it is taking him to same page i.e "http://www.test.com/UK"
Could you pls help and sugest if anything is wrong on the iRules?
- muzammil_88686
Dear Team,
Could you pls suggest me? - muzammil_88686
anyone suggest...? - muzammil_88686
Dear Dev Team,
Could you pls give your expert suggestion?
Best Regards,
