redirecting from HTTPS to HTTP issue !!!!
Hi Experts, I faced abnormal behavior, I've 2 virtual servers HTTP and HTTPS for the same VIP when I access the backend server using http (e.g http://.com/) everything goes well and redirect me to login page properly (e.g http://.com/login). BUT, when I access it using https (e.g https://.com/ ) it directs me to login page but as http (e.g http://.com/login), which is abnormal behavior to me where there is no any iRule applied. so waht could be the issue?
Thnx In Advance.
- rob_carr
Cirrocumulus
It sounds like your backend server may sending a redirect with a location header containing http rather than https. The 'http' profile has an option, 'rewrite redirects' that may fix this issue for you.
- refra_151287
Cirrus
the issue resolved after redirect the traffic from HTTP to HTTPS using sys_https_redirect irule, i think it was backend server behavior issue.
