Redirect non www and https issue
Hi, We have two Irules on a Virtual Server pool that seem to be causing an intermittent issue for some clients / browsers.
_sys_https_redirect (the default F5 one included on the BIGIP boxes) and our own custom one shown below.
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "pennyforlondon.com" } { HTTP::respond 301 Location "https://www.pennyforlondon.com[HTTP::uri]" } }
We have our Irule first followed by the _sys_http Irule.
This however gives us the following error in the logs.
TCL error: /Common/_sys_https_redirect - Operation not supported. Multiple redirect/respond invocations not allowed
The issue we face is if we remove either of these it causes issues displaying the website so we need to use them both.
We support non www, www. and forward from http force it to use https for our SSL cert to work.
Any ideas on how these two Irule can co-exist and not cause weird intermittent redirection issues which only some clients get on occasion.
Thanks, Dylan.
- nitass
Employee
can you try something like this?
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "pennyforlondon.com" } { HTTP::respond 301 noserver Location "https://www.pennyforlondon.com[HTTP::uri]" Connection Close event HTTP_REQUEST disable } }by the way, why don't you combine irules together? shouldn't it be simpler and cleaner?
- nathe
Cirrocumulus
Dylan - would this one iRule work?
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "pennyforlondon.com" } { HTTP::respond 301 Location "https://www.pennyforlondon.com[HTTP::uri]" } else { HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri] } - Michael_Jenkins
The best way that I've found to do this is using the
command More info here.eventBecause you can't have multiple redirects, you would either need to set a flag to say a redirect has already occurred and check it later (which obviously wouldn't work for the built-in rule). Otherwise, you could use the event command. I would say you could change the Location header in the HTTP_RESPONSE event, but I don't think that gets executed when you do a redirect from an iRule.
So, my suggestion would be something like this:
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "pennyforlondon.com" } { Disable further events for this connection event disable all Redirect the user. Make sure to add the Connection Close header because the event command is set per connection. So we need a new connection in order for the rules to execute again. HTTP::respond 301 Location "***REPLACE***[HTTP::uri]" "Connection" "Close" } }NOTE: Replace
with https://www.pennyforlondon.com. The editor messes up URLs when posting, so just replace it in your iRule and you should be good.***REPLACE***Hope this helps.
- DScottSLC_13452
Thanks for all the fast responses, amazing! I will be testing each of the above solutions over the next day or so and post the results. Very much appreciated all feedback to date.
- markgriffin
Many thanks Michael. Just used your iRule to fix a similar issue I was having. Worked a treat! :)
