Lalitha_379027's avatar
Lalitha_379027
Jan 17, 2019
Reboot Volume of BigIP from BigIq
Need to reboot volume of BigIp from BigIq using BigIQ REST API.Through BIGIQ GUI we can do in device properties.Similarly like to do using REST API.Please suggest.
  • To reboot a BIG-IP box from a different volume (say from HD1.1), run this:
    curl -sku : https:///mgmt/tm/sys -X POST -H "Content-type: application/json" \
      -d '{"command":"reboot", "volume":"HD1.1"}'
    To check the available volumes, run this:
    curl -sku :https:///mgmt/tm/sys/software/status
    The endpoints belong to BIG-IP, not BIG-IQ specific, but they should work from BIG-IQ. For details, please refer to the Command section (pp. 57-65) of iControl REST User Guide Version 13.1.
    The equivalent local tmsh commands are
    tmsh reboot volume HD1.1
    and
    tmsh show sys software status
    respectively.
