Yugandhar's avatar
Yugandhar
Jul 18, 2018
Reason for iRule Execution Error
Hi
Multiple URLs are pointing to the same Virtual Server IP but persistence of 600 secs is needed only for a few of them.
Configured the below iRule and applied to the VS but got an Execution error.
                if { [string tolower [HTTP::host]] equals "access.testxyz45.com" or "abc.testxyz45.com" or "def.testxyz45.com" or "mail.testxyz45.com" } {
                      persist source_addr [IP::client_addr] 600
                } else { }
Could you please help as i am unable to figure out the error.
Thanks,
Yugandhar.
  • err tmm5[17765]: 01230140:3: RST sent from 10.16.240.15:443 to 192.168.25.56:49366, [0x2684cbf:1410] iRule execution error
  • You if statement is wrong, please try using this iRule, I've used a switch statement as it is less cluttered than several 'or' statements.
        switch -glob -[string tolower [HTTP::host]] {
            "access.testxyz45.com" -
            "abc.testxyz45.com" -
            "def.testxyz45.com" -
            "mail.testxyz45.com" {
                persist source_addr [IP::client_addr] 255.255.255.255 600
  • Hi Yugandhar.
    You have a syntax problem. your condition need to be explicit for each value.
    you can't set one condition with multiple value. look what you should have done:
    if { [string tolower [HTTP::host]] equals "access.testxyz45.com" or [string tolower [HTTP::host]] equals  equals "abc.testxyz45.com" or [string tolower [HTTP::host]] equals  "def.testxyz45.com" or [string tolower [HTTP::host]] equals   "mail.testxyz45.com" } {
    } else { }
    By the way you have to optimise your irule by set your host variable:
    set host [string tolower [HTTP::host]]
    if { $host == "access.testxyz45.com" || $host  == "abc.testxyz45.com" || $host ==  "def.testxyz45.com" || $host == "mail.testxyz45.com" } {
    } else { }
    and finally you have to optimize his irula for his execution as shown by lee:
        switch -glob $host {
  • JG's avatar
    JG
    Try this one to see if there is a difference:
        if { [string tolower [HTTP::host]] equals ( "access.testxyz45.com" or "abc.testxyz45.com" or "def.testxyz45.com" or "mail.testxyz45.com" ) } {
  • Will go bit different way to solve issue. It will be easy to add more url in datagroup
    class
    . Lets try and update if working.
    class host_url {
        abc.testxyz45.com
        def.testxyz45.com
        mail.testxyz45.com
           if { [matchclass [string tolower [HTTP::host]] equals host_url] } {
           persist source_addr 255.255.255.255 600
             persist source_addr [] [] -- DevCentral Syntax
           Link : https://devcentral.f5.com/wiki/iRules.persist.ashx
    I will request user to click iRule which working and solving issue. So that other can be refer.
    • Yugandhar's avatar
      Yugandhar
      Hi F5_Rock,
      Thank you for providing the iRule, Can we use a Switch Statement instead of an If stmt.
      class host_url {
      abc.testxyz45.com
      def.testxyz45.com
      mail.testxyz45.com
          host_url {
      Thanks,
      Yugandhar.
    • Samir_Jha_52506's avatar
      Samir_Jha_52506
      Icon for Noctilucent rankNoctilucent
      Syntax is different for switch statement. @youssef has already provided switch iRule. Refer his iRule n let us know if any issue.
      Yugandhar
      Thank you .. I thought 'host_url' will be replaced with the values specified in the Data Group...So we can't refer a Data Group in the Switch Statement :)
