splion_86861
Apr 28, 2011Read Configuration from virtual servers
Hey,
is there a way to read the complete configuration from a virtual server with iControl?
My idea is the backup of a given configuration and a restore later, respectively on an other machine.
bye Andreas
- iControl wasn't built to be able to extract the config for a single object. While you could do so by individually querying all the associated get_ methods and storing those values separately, it might be better to just download the configuration with the System.ConfigSync.download_configuration() method which will get you the entire bigip.conf (or bigip_base.conf) files. Granted, you'll have to strip out the pieces you need for just your virtual, but at least all of the configuration objects will be present.
-Joe - splion_86861
Hey,
thank's for your reply. I assumed this.
Can i call the bigpipe-tool remotely with iControl?
I use the bigpipe export on the device to get the actual config and i compare a concatination of
bigip{,_base,_local_sys}.conf with this. The files not 100 percent identical in some sections.
What's the better base for configuration, the bigpipe-output or the bigip-config-files?
bye
Andreas - Unfortunately there is no "bigpipe" call from iControl. I actually proposed this to PD a while back but it never made it into the product. Not sure of the best solution for storing output into a way to merge back in. Either way should work as long as you are importing back into a "like" version of LTM.
-Joe
