Re-starting csyncd
Hi i have upgraded my Viprion Chassis 11.4 to 12.1.2 and we have a custom script to monitor the chassis interfaces. so i copied the script and pasted it in the root folder the script is working fine in other chassis in 11.4 version. but when i run the script manually in the chassis with 12.1.2 it throws this following error.this is not stopping.please help how to stop this. and what is service about does it affect anything if i stop it?
May 22 14:16:26 slot2/F5DENMGT1 emerg logger: Re-starting csyncd
May 22 14:16:28 slot2/F5DENMGT1 emerg logger: Re-starting csyncd
May 22 14:16:32 slot2/F5DENMGT1 emerg logger: Re-starting csyncd
May 22 14:16:34 slot2/F5DENMGT1 emerg logger: Re-starting csyncd
May 22 14:16:38 slot2/F5DENMGT1 emerg logger: Re-starting csyncd
- Anesh
Cirrocumulus
As per article K89999342
For all platforms, the csyncd process populates the software image table. In addition, on VIPRION systems, the csyncd process replicates portions of the file system between cluster members. `-
Instead of manually copying, sync the file from the peer device
Also, You can try restarting the service
`clsh bigstart restart csyncd
