JRahm
Admin
Aug 16, 2011Re: load_configuration
What do you mean the iRule didn't operate? It didn't run at all, or it didn't do what you expected? After your script runs, have you verified that the external datagroup was updated in the file system? The load configuration serves to load in any changes you made to that external datagroup, as well as loading all other bigip configuration objects. If you specify the high level, this is traffic management level objects (rules, snats, routes, virtuals, profiles, pools, etc) whereas the base level is stp, vlan, self ip, mgmt info, etc.
The methods are not configurable.
