Re: HA between GTM
so, the box is dedicated for GTM. so by doing GTM-Sync-Group will all the device configs will be replicated like users/certs/settings? or only GTM stuff will be replicated?
I want it to be a replica of the existing GTM device with all general settings along with GTM stuff so I can cut over once everything is ok.
  • Paulius's avatar
    Paulius
    Icon for MVP rankMVP
    If this is a GTM what other configuration are you referencing? If you have the GTM in the sync group it will replicate all GTM configuration between the GTM devices in the sync group, less their unique configuration such as self-IPs, routes, and so on.
