Puneet_110030's avatar
Puneet_110030
Nov 22, 2013
Rate limiting traffic for exchnage OAB using source ip addresses/subnets
Hello There, I have a single VIP that takes care of multiple client requests for MS exchange 2013 like outlook web access, offline address book etc and i have achieved it using I-rules.
Here is what my irule looks like:
Exchange 2013 iRule to select pool without persistence when all Exchange HTTP-based services are accessed through the same virtual server.
when HTTP_REQUEST { switch -glob -- [string tolower [HTTP::path]] { "/microsoft-server-activesync" { pool Exchange_prod_2013_as_pool7 COMPRESS::disable CACHE::disable return } "/owa*" {
        pool Exchange_prod_2013_owa_pool7
        return
    "/ecp*" {
         Exchange Control Panel.
        return
    "/ews*" {
         Exchange Web Services.
        pool Exchange_prod_2013_oa_pool7
        COMPRESS::disable
        CACHE::disable
        return
    "/oab*" {
         Offline Address Book.
        persist none
        return
    "/rpc/rpcproxy.dll" {
         Outlook Anywhere.
        COMPRESS::disable
        CACHE::disable
        return
    "/autodiscover*" {
         Requests for Autodiscovery information.
        pool Exchange_prod_2013_ad_pool7
        persist none
        return
    default {
} when HTTP_RESPONSE { if { [string tolower [HTTP::header values "WWW-Authenticate"]] contains "negotiate"} { ONECONNECT::reuse disable ONECONNECT::detach disable NTLM::disable } if {[HTTP::header exists "Transfer-Encoding"]} { HTTP::payload rechunk }
We have a requirement for rate limiting traffic to "/oab" using souce ip/network addresses. I have created an object list containing the subnets i want rate limited, but i am not able to figure out how i can include it in my existing irule above.
I am not looking for an exact answer eventhough it wont hurt, but more importantly i looking for a sense of direction.
Thankyou!
  • mikeshimkus_111's avatar
    mikeshimkus_111
    Historic F5 Account
    Hi Puneet, this DevCentral post might be helpful:
    https://devcentral.f5.com/articles/iruleology-table-based-rate-limiting.Uo-iusRxG-w
    Mike
  • HI Mike,
    Thanks for the response. I have checked that URL, it will work good as long as i intend to do rate limiting based on either uri or source addresses. I want to do both for /oab and i am not sure how i can combine the 2.
    Furthermore my orginal irule starts with global switch and i am wondering if i need to chnage that as well.
    Thanks, Puneet
  • John_Alam_45640's avatar
    John_Alam_45640
    Historic F5 Account
    Puneet:
    This thread should be helpful: https://devcentral.f5.com/questions/how-to-limit-a-client-ip-from-continuously-opening-connections-to-the-server
    There is an irule in that thread.
    You should be able to: 1) add this to your iRUle: when RULE_INIT {
     This is the max requests allowed during "interval" specified below.
    set static::maxRate 10;
     Below is the lifetime of the subtable record in seconds.
     This defines the interval during which requests are tallied. Example: Rate=10 and Timeout=3, allows 10 requests in 3 seconds
     Note: do not use very high timeout because it increases memory utilization especially under high load.
     Note: A rate of 100 in 50 seconds is the same is a rate of 20 in 1 second. But 1 second is a lot easier on memory,
     Because the records expire more quickly and the table does become too large.
    set static::timeout 3;
    And 2) take this section below here, and put it under the /oab part of your switch command. Then it should only limit the /oab uri.
        set getCount [table lookup -notouch -subtable requests [IP::client_addr]]
                if { $getCount equals "" } {
                    log local0. "New one:  getCount=$getCount [IP::client_addr] [clock seconds]"
                    table set -subtable requests [IP::client_addr] "1" $static::timeout $static::timeout
                if { $getCount < $static::maxRate } {
                    table incr -notouch -subtable requests [IP::client_addr]
                    if {$getCount == $static::maxRate } {
                        log local0. "User @ [IP::client_addr] [clock seconds] has reached $getCount in $static::timeout seconds."
                    HTTP::respond 501 content "Request blocked Exceeded requests/sec limit."
                    drop
                    return
    • Puneet_110030's avatar
      Puneet_110030
      John, Many Thanks for your response. While i will certainly give it a shot, i am also looking at the possibility of redirecting the traffic related to "/oab" to a diferent VIP using my existing i-rule. This will allow me to manipulate traffic. Any thoughts on that! Thanks,
      Puneet_110030
      can we add something like "rateclass OAB_RATE_LIMIT" under /oab within the original irule to rate limit traffic related to oab.
      Puneet_110030
      All i want to do use my existing irule, but only rate limit traffic related to subsection /oab. not able to figure out how i can do that
