  • that is going to be an interesting one, doesnt appear the normal radius health monitor can choose anything. you might be able to use an external monitor, but im not quite sure how to send the request then. im not aware of your setup, so it might not be possible. but why not setup radius configuration to handle the non peap-ms-chap-v2 request. for monitoring it doesnt really matter which configuration section handles the request.
  • Eric_Chen_12394's avatar
    Eric_Chen_12394
    Historic F5 Account
    If you can use an external monitor you could try using eapol_test: https://www.eduroam.us/node/19. Setting up a local account for monitoring is a lot simpler.
