Question on CA issued cert for LTM
My company uses Venafi to issue CA certificates. I have a cert generated and imported into LTM. I need to create a client-side ssl profile and it is asking for a key. Exactly which key is LTM referring to, (the server, LTM,etc) that I need to import and add to the profile?
Hi there!
When you generated the CSR (Certificate Signing Request) a key should also have been created. If you created it on the LTM the key should be in the Certificate/Key list on the loadbalancer. If you created it via ie. IIS it would reside in the Certificate store on that server. Either way, you would need both the key and certificate. Hope that makes sense.
/Patrik
