Question about TMSH and high CPU...
So I posted a question about a TMSH script to change SSL certs a week or so ago. I got it to work and it is really cool. My question stems from this, I ran it a few times on my standby unit and it really put a hurting on the CPU. Way up around 80 - 90% I am afraid that my primary is more busy and that might crush it. My first question is if I run it on the standby and then fail over and then sync, am I avoiding that hit? Or will it just be caused by the sync since there are so many changes? My second question is at what point does the CPU start to cause problems for traffic? Thanks Joe
- nitass
Employee
where did you see it? was it system cpu usage in performance graph?
can you post the script here?
- sundogbrew
Altocumulus
I was looking at the dashboard when running it, it took between 2 & 3 minutes. Here is the script
tmsh list ltm virtual one-line|grep old-clientssl|cut -d' ' -f3| xargs -I_ -n1 tmsh modify ltm virtual _ profiles delete { old-clientssl } profiles add { new-clientssl } - nitass
Employee
i do not think configsync will create cpu spike. so, i think making change on standby unit, failover and configsync (to original active unit) should be okay.
just my 2 cents.
