QSFP+ breakout cables (MTP to LC) - How to extend
Good morning,
I'm looking at different options to extend my 40GbE QSFP+ breakout cables (MTP to LC) connection.
The patch cord is only 3m, and I'm looking to extend that connection to 50m.
Would using a 12 fiber strand MTP male to female cable as an extension be a good solution ?
Thank you Jason
- Brad_Parker
Cirrus
We are just about to do this very thing. Another large F5 customer is already doing this here in town. Just use a couple of LC couplers like this, https://www.firefold.com/fiber-adapter-lc-lc and the necessary LC fiber to your switch. Our local F5 engineer confirmed the validity of using these.
- F5_user5_188003
I should of specified, we are not allowed to use any couplers in our environment
- Brad_Parker_139
Nacreous
https://support.f5.com/kb/en-us/solutions/public/15000/000/sol15045.html
Well, you are required to use the F5 transceivers, but according to this SOL you can use a longer equivalent cable and still be supported. The caveat being F5 won't support the cable if there are connectivity issues so it will be a fine line to walk if you encounter any(most likely won't as light through glass is generally light through glass). I would double check with you local F5 rep to confirm the cable you plan to use. You will more likely want to find an 8 fiber MTP male to LC male fan cable like these, http://fibertronics-store.com/8-LC-Duplex-QSFP-MTP-MPO-Multimode-OM3-2mm-Breakout-Cable_c918.htm.
- Brad_Parker_139
Nacreous
Technically I think the MPO/MTP QSFP end is female.
- Brad_Parker
Cirrus
- Brad_Parker
Cirrus
- greentelftth_28
Well, maybe I can help you extend the connection, contact me greentelftth E-mail: [email protected]
- greentelftth_28
Well, maybe I can help you extend the connection, contact me greentelftth [email protected]
