Sanal_Babu
Cirrus
Oct 12, 2018Qlik application not loading properly after applying ASM transparent policy .
Qlik application is not loading properly after applying ASM policy into the VIP.ASM policy in transparent mode and policy type is fundamental.Any thoughts ?
Thanks Babu
- youssef1
Cumulonimbus
can you specify if DataGuard is enabled?
then what kind of behaviour did you have after applying transparent policy?
regards,
