Steve_Brown_882's avatar
Steve_Brown_882
Historic F5 Account
Jul 01, 2009
pycontrol help
Hi Guys,
I am pretty new to python and pycontrol and need a little help with a script I am working on. I think I am missibng something obvious and this may even be more a case of me not fully understanding pyton yet. Any how I would like to have my script return a list of virtual servers, destination IP and destination port. Here is a snippet of my current code which works, but does not return exactly what I am lookign for.
virtual = b.LocalLB_VirtualServer
for vName in virtual.get_list()['return']:
vDest = virtual.get_destination(virtual_servers = [vName])['return']
print vName, vDest
The output looks like this....
vipname [{'port': 443, 'address': '10.1.2.3'}
And I want it to look like...I assume I need to pull the port: and address out of the return, but I have not been able to figure out how.
vipname 443 10.1.2.3
  • Steve_Brown_882's avatar
    Steve_Brown_882
    Historic F5 Account
    Just wanted to add the solution since I just figured it out.
    The code now looks like this...
    import pycontrol.pyControl as pyControl
    host = 'x.x.x.x'
    uname = 'username'
    upass = 'password'
    b = pyControl.BIGIP(
    hostname = host,
    username = uname,
    password = upass,
    wsdl_files = ['LocalLB.VirtualServer']
    vPort = vDest[0]['port']
    vIP = vDest[0]['address']
    vPool = virtual.
    print vName,",",vIP,",",vPort
  • Thanks for posting your update! I'm very weak on my python skills so this will be a good reference to point folks to.
    -Joe
  • Good post, thanks for sharing. Here's another method: it looks like you're calling the iControl portal for each virtual server name separately. iControl and Python's zip() function can save you (and the BigIP!) some time and CPU cycles:
     In [16]: vlist = b.LocalLB_VirtualServer.get_list()['return']
     In [18]: vdest = b.LocalLB_VirtualServer.get_destination(virtual_servers = vlist)['return']
     In [19]: combined = zip(vlist, vdest)
     In [20]: for x in combined:
     ....:     print "%s=>%s:%d" % (x[0], x[1]['address'], x[1]['port'])
    Produces output like: virtual_forward_test=>192.168.1.0:0
    The key bit here is that you can pass in the entire list of VS names to get_destination, and iControl will do the Right Thing and return the ip/port combos back in order. Then you "zip" them together, which will create a tuple by default - you then just iterate through it as if it were a list...
    I hope this helps!
    -Matt
    Steve_Brown_882
    Historic F5 Account
    Thanks for the input Matt. I have incorporated some of you suggestions and it sure runs faster. I also changed the prints because my ultimate goal was to create a CSV to help us create some documentation. Here is the newest version in case anyone wants to see. I am sure it is not the cleanest code but it is still a work in progress.
    pool = b.LocalLB_Pool
    vlist = virtual.get_list()['return']
    state = virtual.get_enabled_state(virtual_servers = vlist)['return']
    vdest = virtual.get_destination(virtual_servers = vlist)['return']
    vpool = virtual.get_default_pool_name(virtual_servers = vlist)['return']
    member = pool.get_member(pool_names = vpool)['return']
    combined = zip(vlist, state, vdest)
    file = open("BigIP.csv", "w")
    file.write('Virtual Server Name,Virtual Server State,Destination IP,Destination Port')
    file.write("\n")
    file.close()
    for x in combined:
    details = x[0]+ "," + x[1] + "," + str(x[2]['address']) + "," + str(x[2]['port'])
    file = open("BigIP.csv", "a")
    file.write(details)
    file.write("\n")
    file.close
