Ted_51200's avatar
Ted_51200
Mar 28, 2008
Pull info from SSL Client Cert
I need an irule to pass on Client Cert information from a HTTPS request to the backend pool
Attributes I'd like sent along in HTTPS headers:
Certificate status - The status of the client certificate. The value of [status] can be NoClientCert, OK, or Error. If status is NoClientCert, only this header is inserted into the request. If status is Error, the error is followed by a numeric error code.
Certificate serial number
Issuer of the certificate
Certificate subject (Distinguished name or DN)
Thanks to anyone that can help me out.
  • Hi,
    To do so you'll need the BIGIP to be the SSL termination of the the HTTPS flow.
    Then you can use those commands to do the kjob :
    Certificate serial number: Click here
    Certificate issuer: Click here
    Certificate subject: Click here
    An example of certificate manipulation can be found here: Click here
    to insert HTTP header it is simple: Click here
    Here is an example of code to work from:
    when HTTP_REQUEST
      set pkiSubject [X509::subject $the_cert]
      set pkiIssuer [X509::issuer $the_cert]
      HTTP::header insert CN $pkiSubject
      HTTP::header insert SSLIssuer $pkiIssuer
      HTTP::header insert SSLClientCertSN [regsub -all {:} [X509::serial_number $the_cert] -]
