Publishing NDES through F5 reverse proxy
I’m planning an SCCM+Intune+NDES integration for mobile device certificate enrollment. Ideally customer want to publish NDES with its F5 appliances. Given what there's written here
Does anyone knows, or has already configured and it works, if there will be problems publishing NDES with F5 appliances acting as reverse proxy?
Thanks in advance
- Brett_Verney_29
Hi there,
Did you ever figure this one out? I have just put an NDES server behind an F5 appliance and may be running in to the exact same issue! I came across the same link as well as this post of yours while doing some research.
-Brett
- snerssessian
Hello,
Just wanted to ask if anyone has implemented this configuration as we also do not want to deploy the MS WAP servers and instead we would like to leverage our existing F5 appliances.
-Shawn
