Publish an application using APM and bypass DNS
Hello,
We have VS for an application call "Test" with dst IP: 10.10.10.10
In the organization's DNS, "Test" IP is: 172.16.10.10
We want to publish "Test" using APM.
In Access Policy -> Portal Access -> Portal Access List
When creating a new object to be published,
In "Application URI" I wrote: ""
In the local HOSTS file (System -> Configuration -> device -> Hosts)
I added that 10.10.10.10 = "Test"
When doing ping from the F5 shell to "Test" I get "10.10.10.10" as expected
But, when using TCPDUMP to catch the packets while clicking on the object from the full webtop,
I see that F5 is communicating with "Test" using his real IP 172.16.10.10.
How can I force the APM to go to "Test" with IP address 10.10.10.10 and without using the DNS resolution?
Regards,
Noam.
- Seth_Cooper
Employee
Hi Noam,
Unfortunately you are hitting a limitation of the system that is being tracked by ID 223060. To help prioritize this ID I would suggest opening a case with support asking to be linked, which will give attention to this being fixed.
Seth
- NoamRotter
Altostratus
Thank you anyway...
I will open a ticket.Regards.
- jefp_185700
any idea if this bug id is solved yet? We have the same issue...
- jefp_185700
