JasonHeffner_71
Jan 16, 2009Nimbostratus
ProxyPass redirect problem
I'm having some strange issues with proxypass and redirects. I have proxypass setup as follows
/login some.server.edu/login connectstagingapp
/manage some.server.edu/manage connectstagingapp
and generally this works as expected. However when I attempt to do a response.redirect in asp which is behind proxypass to a url outside on the same server, the BigIP will continue to serve files through proxypass for all urls on the host, even those that aren't specifically listed in the Data Group List.
The stranger thing this is dependent on browser, where this is the case on Firefox and IE, Safari will correctly handle the redirect.
Does anyone have an idea what might be causing this?
- JasonHeffner_71NimbostratusI tried your changes above and the same behavior still happens. I do have time to troubleshoot this, so I may go digging as well. Someone mentioned just using some simple HTTP classes so might look into that first.
- JasonHeffner_71NimbostratusStill no joy.. I replaced the smileys and the [virtual] with [virtual name] since I'm running BIG-IP 9.3.1 Build 37.1
- hooleylistCirrostratusCan you post an anonymized copy of the VIP config (b virtual VIP_NAME list), the iRule configuration parameters from RULE_INIT and logs of the failure with debug set to 2?
- JasonHeffner_71NimbostratusI was reading your mind.. Here is a failure.
- hooleylistCirrostratusSorry, can you uncomment the section for SERVER_CONNECTED? Also, if you're not rewriting the response content using a stream profile you can set ::rewrite_response_payload to 0 in RULE_INIT.
- JasonHeffner_71NimbostratusHere is the new log. At the end of the failure I continued to hit reload a few times as it went to the wrong pool. I then waited about 4 minutes and hit reload and the system went to the correct page.
- hooleylistCirrostratusI think I found the problem. I edited the post above. Can you retest the updated iRule?
- JasonHeffner_71NimbostratusThat did it!! Awesome Job! I'm glad I was able to help improve the code. If you need any more debugging or testing let me know.
- JasonHeffner_71NimbostratusI can close the call I had open.
- hooleylistCirrostratusGreat to hear. Thanks for the help testing.
Â
