serebra_83282's avatar
serebra_83282
Jul 08, 2009
ProxyPass problem
Greetings,
I followed the instruction on http://devcentral.f5.com/wiki/default.aspx/iRules/ProxyPass to set up ProxyPass and got problem.
In browser, it said:
Connection Interrupted
The connection to the server was reset while the page was loading.
The network link was interrupted while negotiating a connection. Please try again.
In Big-IP log /var/log/ltm, it said:
Jul 8 16:46:24 tmm tmm[1577]: 01220001:3: TCL error: ProxyPass - beta while executing "virtual name"
Here are the configurations:
virtual beta {
pool betapool
destination 172.16.0.24:http
ip protocol tcp
rules ProxyPass
profiles
http
oneconnect
tcp
class ProxyPassbeta {
" www.site1.com/support www.site2.com/support"
BIG-IP 9.4.3 Build 1.4
Idea?
Thank you!
  • I even tested follow simple code (posted at http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&postid=59883&view=topic) to proxy client request http://www.site1.com/nilo to http://www.site1.com/bcda, it did not work, got same error.
    Initialize a variable to track whether to rewrite the response headers/content
    set check_response 0
    Check if the path is correct
    if {[HTTP::uri] starts_with "/nilo"} {
    Track that we'll rewrite the response headers and possibly the payload for this app
    set check_response 1
    when HTTP_RESPONSE {
    Check if we're potentially rewriting the response headers/payload for this app
    if {$check_response}{
    Check if JSESSIONID cookie exists
    if {[HTTP::cookie exists JSESSIONID]}{
    Set the path on the cookie to /sdr/nilo so the client will send the cookie in requests for any path
    HTTP::cookie path JSESSIONID "/sdr/nilo"
    Check if the response is text
    if {[HTTP::header value Content-Type] contains "text"} {
    Set the replacement text and enable the stream filter
    STREAM::expression {@/nilo/@/bcda/@}
    STREAM::enable
    Response isn't text, so disable the stream filter
    STREAM::disable
    By the way, www.site1.com/bcda/ is existed.
    Thank you,
    Victor
  • hoolio's avatar
    hoolio
    Hi Victor,
    When you tested with the updated HTTP::header Host replace... command the logs show the rewrite worked:
    When using 'HTTP::header replace Host $host_serverside', here is the log:
    Jul 10 09:41:54 tmm tmm[1577]: Rule ProxyPass : beta, Host=www.site1.com, URI=/support/index.htm: Current Host header value: www.site2.com, URI: /support/index.htm
    When you used the original iRule, it didn't work:
    When using 'HTTP::header replace header_name: header_value' , here is the log:
    Jul 10 10:04:59 tmm tmm[1577]: Rule ProxyPass : beta, Host=www.site1.com, URI=/support/index.htm: Current Host header value: www.site1.com, URI: /support/index.htm
    Can you update the iRule to use 'HTTP::header replace Host $host_serverside' and test once more?
    Aaron
