Procedures for packet captures
Hi All, I am new to F5 products, are there are any good documents on how to capture and filter traffic???
Thank you
- Peteralex_19213
Thanks kanjun
Do I capture traffic and then save the output ?
or can I capture the traffic to a .bin file and then view via wireshark
Many thanks
- kunjan
Typically you write to a file and read it in wireshark.
eg: tcpdump -ni 0.0 -s0 -w /var/tmp/sample.cap
This will capture all the traffic on all interfaces(0.0) without packet length limiting (-s0) and write to the file.
- Peteralex_19213
Thank you KANJUN wireshark should open the .cap file ? cheers - nitass
Employee
yes
- kunjan_118660
Cumulonimbus
- Peteralex_19213
Employee
yes
