tech_contact_90's avatar
tech_contact_90
Jul 15, 2010
Problems with Outlook Anywhere
Running 9.4.3 Used the f5 doc to for OA, OWA, and Active Sync OWA is working fine, SSL is offloaded. I havent tested Active Sync yet, but we are stuck on Outlook Anywhere. Outlook simply wont connect. I am unsure where to begin troubleshooting. Everything seems to be setup properly, but obviously I must have missed something. If I point directly at the Exchange server and bypass the BIGIP it works ok so I feel confident the exchange is working
  • I'm not too familiar with "Outlook Anywhere" but standard troubleshooting would have you get packet captures between you and exchange and compare them to a capture between you and the F5.
  • hoolio's avatar
    hoolio
    Not that it's related to this problem, but I'd also suggest upgrading to 10.1.0HF2 when you can as there have been a lot of improvements and fixes since 9.4.3.
    Aaron
  • Thanks, we will look into that. Right now, that is not an option for us. As for the network trace, the only information i see that might be relevant is I am getting a 401 Unathorized error when going through the BIGIP, that I dont get when i am going direct. Any other ideas?
  • Posted By tech_contact on 07/16/2010 02:44 PM
    Almost seems related to SSL termination - but not sure. Can you simply set the F5 up to passthrough SSL connections, rather than terminating them?
  • hoolio's avatar
    hoolio
    There's a new post on this here:
    http://devcentral.f5.com/Forums/tabid/1082223/asg/62/showtab/groupforums/aff/25/aft/1174135/afv/topic/Default.aspx
    Aaron
  • Phillip_Hocking's avatar
    Phillip_Hocking
    Historic F5 Account
    Typically when I see this it is because the rpc vip is not defined with the correct persistence profile. You can call in and open a ticket, even though those deployments are outside the scope of our support we can provide best-effort troubleshooting.
