Problems with HA
Hello,
I have downloaded the Bigip LTM VE trial 11.3, but have problems with HA, we use the manual and use the wizards to configure a pair of f5s (active-pasive) but its not posible, all the time gets one node disconneted, but the network and visibility for two nodes is ok !!! I using a one armed scenario, means "internal" and "external" networks are the same, configure NTP and put the default gatweway etc....
Is there are any restriction to do this ??
Somebody May help me ??
Thanks in advance
- nitass
Employee
i am not sure if it won't work or it may work but not supported. hope somebody here has real experience. otherwise, you may request for full-featured evaluation license or buy ve lab edition.
VE Trial edition restrictions and limitations The VE Trial edition software is fully functioning version of the BIG-IP VE, with the following distinctions: Support for 1 core. Support for 2 GB RAM for a single module, or 6.5 GB RAM for multiple modules. Support for up to 10 Access Policy Manager® sessions. Trial version cannot be upgraded. No hotfixes will be created for this version. Although a backup can be created, it can only be associated with the same version. VMware ESXi is the only hypervisor supported. Enterprise Manager™ and BIG-IQ™ Cloud are not supported. BIG-IP High Availability (HA) feature is not supported.Release Note: BIG-IP Virtual Edition 11.3.0 Trial Quick Start Instructions
https://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/big-ip-ve-trial-quickstart-guide-11-3-0.htmlunique_1173373774 - Albert_Clara_13
ok thanks !!!
