Zackus_337084's avatar
Zackus_337084
May 09, 2018
Problems with Deny Page
Hi everyone,
I have little problems with a modification.
I want to modify the /vdesk/hangup.php3. but i can't find how to modifiy it.
The header on the page is good and the "main_table" too but I have a table "main_table_image_cell" with the same picture that I have on my header. I want to delete it but I can't find how to do that.
Thnaks in advance
regards
Zackus
  • Hi Zack,
    You can do it modify source page. For information "/vdesk/hangup.php3" is a logout page.
    So for this you have to modify logout.inc page... - go to Profiles / Policies : Customization : Advanced. - Edit your APM Policy -> Policy name -> Logout -> Logout.inc
    Then modify the page as you want.
    • do the same modification in APM Policy -> Access policy -> ending page -> deny -> Logout.inc
    • Then save draft (Top right)
    • Next click in save (Top left)
    • And finally apply your policy.
    Just do a backup of the page content of efore modification.
    Let me now if you need additional information. Regards
  • thanks a lot you solved my problem, but I have another :) Can I use different header for my logout ? Because the header is a specific page ?
    Thanks in advance
    • youssef1's avatar
      youssef1
      Can you clarify your needed, or show me what's you want to do with header and what header you talking about!!!
    • Zackus_337084's avatar
      Zackus_337084
      Thanks for help!
      I have a page named header.inc, this page is included in all pages (logon,logout....) with a table like that
          code
          code
          code
          code
          code
      but I want to use my page_header_logout id to customize my logout page. If I change the ID by page_header_logout all pages will include the header_logout
      I don't know if i clarify the situation, it's hard to explain 🙂
    • youssef1's avatar
      youssef1
      Hi Zack,
      I understand you need.
      I already manage this king of need using javascript in order to diyplay different text/branding regarding context (URI or another trigger).
      you would like to change text only?
      Regards,
