jk20004_44080's avatar
jk20004_44080
Mar 18, 2016
problems with b64decode decoding signed content
we need to decode a uri from Microsoft owa where the result has about 41 binary Bytes for a signature. we only need the rest but the base64 fails with
conversion error (line 1) invoked from within "b64decode $uri"
i also tried to fix it using substr to cut the binary part Prior to the base64decode without success
any idea?
  • Are you able to provide an example of what $uri contains when the decode fails ?
  • I expected that question :-) sorry no, because in the result are informations i cannot put in a public blog (company policy)
  • THi's avatar
    THi
    Is your uri url-encoded (after the b64-encoding)? I have seen similar error when trying to b64-decode an uri without first url-decoding it.
    Url-encoding replaces unsafe ASCII characters with a "%" followed by two hexadecimal digits, to make it safe to be used in http requests. Trying to b64-decode url-encoded string can fail in this case.
    For example b64encode will add padding depending on the length of the string to be encoded. Sometimes padding is "=" -characters in the end of the b64 string, and those are not good in the uri.
    Example: set decoded_uri [b64decode [URI::decode [HTTP::uri]]
  • the solution can be found in wiki where they describe base64 and "URL applications", and the iRule translation is:
        set uri [string map {- +} $uri]
        set uri [string map {_ /} $uri]
