Problems with Ansible connecting to i4600
Hello, I am new to F5 and to Ansible. I am trying to use Ansible to do a first time configuration of an i4600 in our lab. I can connect to the Big-IP via SSH and GUI, my playbook gathers facts but still fails to connect to devices to run modules.
Code
[user.name@sl7jump2 playbooks]$ ansible-playbook -i hosts onboard2.yaml
PLAY [Onboard Playbook] ************************************************************************************************************
TASK [Gathering Facts] *************************************************************************************************************
ok: [10.12.118.173]
ok: [10.12.118.174]
TASK [Manage SSHD setting on BIG-IP] ***********************************************************************************************
[DEPRECATION WARNING]: Param 'server' is deprecated. See the module docs for more information. This feature will be removed in
version 2.9. Deprecation warnings can be disabled by setting deprecation_warnings=False in ansible.cfg.
[DEPRECATION WARNING]: Param 'user' is deprecated. See the module docs for more information. This feature will be removed in
[DEPRECATION WARNING]: Param 'password' is deprecated. See the module docs for more information. This feature will be removed in
[DEPRECATION WARNING]: Param 'validate_certs' is deprecated. See the module docs for more information. This feature will be removed
in version 2.9. Deprecation warnings can be disabled by setting deprecation_warnings=False in ansible.cfg.
fatal: [10.12.118.173 -> localhost]: FAILED! => {"changed": false, "msg": "Unable to connect to ['10.12.118.173', '10.12.118.174'] on port 443. The reported error was \"HTTPSConnectionPool(host=\"'10.12.118.173',%20'10.12.118.174'\", port=443): Max retries exceeded with url: /mgmt/shared/authn/login (Caused by ProxyError('Cannot connect to proxy.', error('Tunnel connection failed: 503 Service Unavailable',)))\"."}
fatal: [10.12.118.174 -> localhost]: FAILED! => {"changed": false, "msg": "Unable to connect to ['10.12.118.173', '10.12.118.174'] on port 443. The reported error was \"HTTPSConnectionPool(host=\"'10.12.118.173',%20'10.12.118.174'\", port=443): Max retries exceeded with url: /mgmt/shared/authn/login (Caused by ProxyError('Cannot connect to proxy.', error('Tunnel connection failed: 503 Service Unavailable',)))\"."}
to retry, use: --limit @/home/userdir/ansible/playbooks/onboard2.retry
PLAY RECAP *************************************************************************************************************************
10.12.118.173 : ok=1 changed=0 unreachable=0 failed=1
10.12.118.174 : ok=1 changed=0 unreachable=0 failed=1 4 Replies
- Lee_Sutcliffe
Nacreous
Are you able to share your playbook onboard2.yaml?
- Robert_Stenger_
My playbook:
--- - name: Onboard Playbook hosts: i4600 gather_facts: false vars_files: - /home//ansible/playbooks/bigip_vars connection: local tasks: - name: Manage SSHD setting on BIG-IP bigip_device_sshd: user: "{{ username }}" password: "{{ password }}" allow: all login: enabled banner: "enabled" banner_text: " {{ banner_text }}" server: "{{ inventory_hostname }}" validate_certs: no delegate_to: localhost - name: Configure NTP server on BIG-IP bigip_device_ntp: server: "{{ inventory_hostname }}" user: root password: default ntp_servers: "{{ ntp_servers }}" validate_certs: False delegate_to: localhost - name: Configure BIG-IP hostname bigip_hostname: user: "{{ username }}" password: "{{ password }}" validate_certs: False hostname: "{{ hostname }}" delegate_to: localhost - name: Manage BIG-IP DNS settings bigip_device_dns: user: "{{ username }}" password: "{{ password }}" name_servers: "{{ dns_servers }}" search: "{{ dns_search_domains }}" ip_version: "{{ ip_version }}" validate_certs: False delegate_to: localhostMy bigip_vars file:
username: - 'root' password: - 'default' banner_text: "This computer system and associated networks are intended for the business use of and its authorized users. The Company's computers and proprietary data and information stored on them remain at all times the property of . Subject to applicable laws and regulations, users have no right to privacy as to any information transmitted or stored in, by or through any portion of this system." ntp_servers: - '10.12.132.2' - '10.12.132.3' dns_servers: - '10.12.59.40' - '10.12.59.41' dns_search_domains: - 'local' - 'localhost' ip_version: 4 hostname: - 'fna-lb01_ansible' - 'fna-lb02_ansible' item.name: ltm inventory_hostname: - '10.12.118.173' - '10.12.118.174'My Host file:
LAB Big IP Host file [i2600] 10.12.118.171 10.12.118.172 [i4600] 10.12.118.173 10.12.118.174 - Lee_Sutcliffe
Nacreous
I can't see anything glaringly wrong with your playbook, does it work for hosts [i2600]? It does however look like a proxy issue, do you have one configured? It it possible to by-pass the proxy?
- madhu
Hello Robert - Were you able to figure this out? i have the same issue but with different end devices.
