matm_58717's avatar
matm_58717
Feb 15, 2017
Problems comparing memberof variable
We have APM provisioning and trying use a iRule to discard the conection if session.ldap.last.attr.memberOf variable contains a certain value. This is the iRule:
when ACCESS_POLICY_COMPLETED {
set aux 0
if{[ACCESS::session data get "session.ldap.last.attr.memberOf"] contains "TEST" } {
$aux = 1
switch -glob [HTTP::uri] {
            "/URI_A/*" {
                        pool /Common/P-URI_A
            "/URI_B/*" {
                        pool /Common/P-URI_B
            "/URI_C/*" {
                        pool /Common/P-URI_C
            "/URI_D/*" {
                        pool /Common/P-URI_D
            "/URI_E/*" {
                        if{($aux == 0)}{
                        discard
            default {
                        pool /Common/P-URI_DEFAULT
The if{[ACCESS::session data get "session.ldap.last.attr.memberOf"] contains "TEST" } Inside to ACCESS_POLICY_COMPLETED event report this error:
Feb 15 11:37:36 slot3/DEVICENAME err tmm1[30518]: 01220001:3: TCL error: /Common/IRULE_TEST  - invalid command name "if{| CN=XXXX,OU=XXXX,OU=XXXX,OU=XXXX,OU=XXXX,DC=XXXX,DC=XXXXX,DC=XXXX | CN=XXX,OU=XXX,OU=XXX,OU=XXX,OU=XXX,DC=XXX,DC=XXX,DC=XXX |
We have several doubts:
What event is running before?(HTTP_REQUEST or ACCESS_POLICY_COMPLETED) Why does not the "if" work? by the type of variable?
Thanks!!
  • JG's avatar
    JG
    Try this one:
    when ACCESS_ACL_ALLOWED {
        set aux "[ACCESS::session data get session.ldap.last.attr.memberOf]"
        if { $aux contains "TEST" } {
            $aux = 1
            $aux = 0
                "/URI_A/*" {
                "/URI_B/*" {
                "/URI_C/*" {
                "/URI_D/*" {
                "/URI_E/*" {
                               if {($aux == 0)}{
                                   discard
                default {
