achatt's avatar
achatt
Feb 26, 2024
probleme java with f5 bigip
Good morning, after updating Google Chrome to Version 122.... applications are no longer accessible via f5
  • rzoll's avatar
    rzoll
    We're running into the same issue, both Edge and Chrome updating to v122 breaks the URI webtop link to the application. Dev Tools show the cache-fm-Modern.js breaking.
    • rzoll's avatar
      rzoll
      I was just coming back to report my findings- I don't think that we need to have caching enabled for our application, and the js error stopped when I turned off caching. We (as in my team and I) try to practive Read Only Fridays, but your link looks like a better solution long term.
      • vrocha's avatar
        vrocha
        Unfortunately turning cache off didnt work for me ): I will let you guys know if my solution worked
