TWSS_18275's avatar
TWSS_18275
Jun 04, 2008
Problem with Switch
We are attempting to setup an iRule that will use a different pool based on the uri string. The problem we are having seems to be "sticky" pools. Here's the iRule:
    switch -glob [string tolower [HTTP::uri]] {
      "/path/*" {
        persist none
        log local0. "PWR -- old pool: '[LB::server pool]'"
        pool pool_imagesrv
        log local0. "PWR -- new pool: '[LB::server pool]'"
      default {
        persist none
        log local0. "DEFAULT -- old pool: '[LB::server pool]'"
        pool pool_test
        log local0. "DEFAULT -- new pool: '[LB::server pool]'"
and here's a snapshot of the logfile:
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : DEFAULT -- old pool: 'pool_test'
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : DEFAULT -- new pool: 'pool_test'
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : PWR -- old pool: 'pool_test'
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : PWR -- new pool: 'pool_test'
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : DEFAULT -- old pool: 'pool_imagesrv'
  Jun  4 08:31:47 tmm tmm[1153]: Rule test_irule : DEFAULT -- new pool: 'pool_imagesrv'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : PWR -- old pool: 'pool_test'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : PWR -- new pool: 'pool_test'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : PWR -- old pool: 'pool_imagesrv'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : PWR -- new pool: 'pool_imagesrv'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : DEFAULT -- old pool: 'pool_imagesrv'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : DEFAULT -- new pool: 'pool_imagesrv'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : DEFAULT -- old pool: 'pool_test'
  Jun  4 08:31:48 tmm tmm[1153]: Rule test_irule : DEFAULT -- new pool: 'pool_test'
If you look, it appears that a request has to happens twice for a uri string before the pool gets change. Not sure what the cause is, any ideas?
  • hoolio's avatar
    hoolio
    Deb added a helpful post on OneConnect which explains the issue you're seeing:
    OneConnect? For my iRule?
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=114
    As an aside, if you add the TCP::client_port in each log statement, I think you''ll see an interesting pattern.
    Aaron
