Problem with string map : TCL
Hi Team,
I test this two commands to replace $num with $num_fin in each ligneptf but with no result, the file isn't modified
string map -nocase [list $num $num_fin] $ligneptf
puts [string map -nocase [list $num $num_fin] $ligneptf]
if you have an idea , thank you in advance.
- Thomas_Gobet
It should work but your problem may comes from that you didn't save this "new" variable. It replaces every occurrence but you have to save it manually.
For example what you can do is :
set new_ligneptf [string map -nocase [list $num $num_fin] $ligneptf] - Ddib_147504
thank you, it works but it copies the line on the next line, can we replace the line directly in the same file without creating a new temp file?
