problem with ssl cert
I have generated csr via gui on my f5. Then I send this csr to the CA. In response I got cert and bundle.
I tried to instal this on f5, but i have got info about key mismatch. I did this entering the csr, and importing cert file.
First question, does the csr having validation time? Second question, did CA should send me a key file?
R. M
- Kevin_Stewart
Employee
Not usually
It should NOT be a private key. A CSR is generated from a private key so it's assumed you already have one. The most likely reason is that the data you have is not in the right format. Open the file in a text editor. You should see something like this:
----- BEGIN CERTIFICATE ----- ... a bunch of base64-encoded certificate data ... ----- END CERTIFICATE -----If there's more than this in the file you'll want to extract this content into a separate file and import that as your public certificate.
