Problem With Publish inside App so i will be reach it from Outside
Hi all
We have in our organization F5 LTM
i have inside app that have the server ip address 10.7.4.94
But the app speak with the server in the FQDN name of "app-server.ashdod.eu"
now the app-server.ashdod.eu is inside address
but the address that i try to reach to from the world is "FrontEnd.ashdod.muni.com"
now my problem is that when i reach to "FrontEnd.ashdod.muni.com"
i get from the app
"Error loading https://app-server.ashdod.eu/portal/sharing/rest/portals/self?f=json&callback=dojo_request_script_callbacks.dojo_request_script0"So from what i see the app return instead of FrontEnd.ashdod.muni.com its return app-server.ashdod.eu that is inside address
any suggestion ?
- Andrew-F5
Employee
Dudi,
Your server is likely sending app-server.ashdod.eu in a location header on response so the browser then requests 'app-server.ashdod.eu/path/'.
You will need to rewrite the host on both client and server side requests/responses.
Client request: FrontEnd.ashdod.muni.com > (F5) change FrontEnd.ashdod.muni.com to app-server.ashdod.eu > Send to server
Server response: app-server.ashdod.eu > (F5) change app-server.ashdod.eu to FrontEnd.ashdod.muni.com > send to response to client.
Refer to https://devcentral.f5.com/s/feed/0D51T00006i7Vu6SAE, @frisco76 104868 for credit.
when RULE_INIT { set ::external_hostname "FrontEnd.ashdod.muni.com" set ::internal_hostname "app-server.ashdod.eu" Enable debug logging to /var/log/ltm. 1 = yes, 0 = no set ::hostname_rewrite_debug 0 } when HTTP_REQUEST { if {$::hostname_rewrite_debug}{log local0. "Original URL: [HTTP::host][HTTP::uri]"} HTTP::header replace "Host" $::internal_hostname if {$::hostname_rewrite_debug}{log local0. "New URL: [HTTP::host][HTTP::uri]"} } when HTTP_RESPONSE { if { [HTTP::header value "Location"] starts_with "$::internal_hostname" }{ if {$::hostname_rewrite_debug}{log local0. "Inside of HTTP::header location, orig HTTP location equals: [HTTP::header location]"} set ::location [HTTP::header location] HTTP::header replace location $::external_hostname if {$::hostname_rewrite_debug}{log local0. "Inside of HTTP::header location, new HTTP location equals: [HTTP::header location]"} } }
