mrp_235984's avatar
mrp_235984
Feb 05, 2016
Problem with F5 heartbeat
I’m having a problem with the heartbeat on the new F5’s for the Intranet. The interfaces are up, but I can’t ping across them. I’m thinking it might be a F5 SFP or switch port.
  • Hamish's avatar
    Hamish
    I'm thinking you haven't provided enough information here to know for sure...
    What are the interfaces connected to? At which speed & duplex? Are they on the same VLAN? Do you KNOW they're on the same VLAN (i.e. can you prove it. If it's a cisco switch then CDP is a big help here)? LLDP is a big help too if it's not a cisco switch.
    If you tcpdump on the interfaces do you see traffic inbound from the other node? What about outbound? (Hint, tcpdump at both end simultaneously. You can eliminate a lot of potential problems if you know where the traffic is going missing).
    H
