Problem with exchange_2010_2013_cas.v1.5.1 iApp
Hi guys,
I'm currently working on migration of BIG-IP 3900 to a brand new vCMP hosted on BIG-IP 7250.
On the old (BIG-IP 3900) we have iApp exchange_2010_2013_cas.v1.4.0 deployed which works perfectly fine.
I would like to deploy a newer version of the same iApp on the new box (BIG-IP 7250).
New Virtual Server will have an IP address from the same subnet/vlan as the old one and will be pointed to the same CAS - pool members. I will be using different self IPs etc.
Both F5 appliances share the same VLANs (Internal, External and Exchange) but all IPs are different - no IP conflicts.
The question which I have is - can the deployment of the new iApp on the new BIG-IP affect somehow the current setup without changing DNSes and autodiscovery IP addresses?
- Domel_163525
Hi Mikeshimkus,
Thanks for your answer.
I have run a test deployment yesterday and for some reason all outlook clients started receiving some weird autodiscover warnings so had to quickly remove it.
Any ideas what could cause it?
- mikeshimkus_111Historic F5 Account
Hi Domel, if I understand the question, you shouldn't have any issues as long as you use a different IP address for your new deployment. You will see double the monitor traffic when looking at connections on the CAS servers, which could impact troubleshooting.
